did you gas foul the plug so it won't fire?
Since my original post to this thread I ran into a "no start" day and feel I flooded the thing in COLD 0 degree weather. I let it set until the temps got above 20 and added a little heat or some such thing and fresh gas - she fired right up. As mentioned - get a new plug. My next oil change will likely be a 0 (zero) weight synthetic as all(99%) of my work is in cold weather and oil can become near jelly in the crank case making the pull start a bear!! I need an electric start.
Might stick an aquarium heater in it when I cut in the cold.
Cheap dipstick type oil heater from an autoparts store?
Does the entire rod on the dipstick heater get warm? If so, that could be a problem and possibly melt the side of the plastic can.
copper plugs are cheap... I'd change it and try again...
My homemade splitter was built by my uncle a looooong time ago... it's 1960's tecumseh engine with electric start that runs like a champ... as long as I give 'er a new plug each fall.
Gotta love that spark test!Even though I felt an electrical charge
:DFigures I type this.....
... and this morning I'm out there with a battery charger, wrenches and a can of carb cleaner...
carb's clean now and it runs again... lol
