The bigger the better. You can always turn a big stove down but you can't, or shouldn't, turn a little stove up beyond its rating. Some do and wonder why they shut down or even warp.You now have no choiceMy boss doesn't care haha. She says the p61 because it's larger output capability
My stove is rated up to 40,000 BTU's. Most nights, I run it on 3. The coldest nights I will sometimes set it to 4.How many btus do you have
No I'm not saying that. What I'm saying is if the p43 cooks you out of the room and doesn't heat the house, then cooking the room more serves little advantage unless you can get the heat out of the room instead of you. Turning the p61 down, which, it will do, leaves you where you are at then, no ? The correlation is more like the P43 on full blast is about like the P61 on level 4.5- 5 actually. But just as a test have you tried stove temp up around 5 or 6 to see if the P43 can do a better job than it is in room temp. In your situation I think Room temp is getting squelched too soon before heat can get out in to the main house. Stove Temp offers a more steady output from the stove. I'm asking if you tried that ?So you are saying the lowest on p61 will be stove temp 5 on the 43?
What about the xxv
OK, so if you up the P43 to 6 in stove what happens, what is the result besides using a few more pellets obviously ?Hey, I do only use stove temp- I don't like room temp.
I use it at 4 or 5 and it does seem to move it upstairs. I am getting a fan installed in the main foyer to help move the heat.
You're right, I need to move the heat. Thanks for your input again.
I know the XXV is a diff ballgame but if I can move heat, I am wondering if the xxv will be better than the 43 or if the sure bet is 61
My boss doesn't care haha. She says the p61 because it's larger output capability but I like the xxv as I hear it's quieter.
I'm gonna go with p61
Ya, if you can stand it in the room the stove is in then try more in a couple of hours. Also high fan. Then see how the house does in due time. It takes a bit of time. This is an experiment, so don't be afraid to turn the dial !Just cranked it to 5 and feed to 4.
See how the P43 does bumped up before you get into all that.That's good advice. I will see how it goes tonight. Do you think the xxv would move too
