St Croix Prescott model and manufactured date difference.
d-dayman
44
Central Pennsylvania
I picked up a used 2006 St Croix Prescott this past February for a good deal. It runs great but since it’s used I’m concerned of eventual failing parts. I recently found another used Prescott locally for $300. I was thinking of buying it for backup parts. Or just to have a second unit. Says it needs a new auger motor. My question is are the parts compatible between the two? The 2006 is a Prescott EXP and the other I’m thinking of buying is a 2004 EXL. They look identical except the bases of coarse. I was wondering if the fans/motors, circuit boards, auger, verse grate, etc. are the same.
Thanks
Most parts should be the same. Control boards may be different and that's obvious from looking at control panel membrane. Personally I think the Prescott is a wonderful stove. Efficient, very l oi w maintenance and reliable.
The unit with bad auger may just need lube on top auger bushing which dry out from the heat and seize.
