My last post I spoke about my glass gasket on the stoves door.
This is what I found out from the St Croix CSR:
1-The gasket is supposed to be around all glass panels and they can't understand why it wasn't. (I can, lack of quality control) so a complete gasket set is to be mailed out.
2- Under their Shabby Warranty: According to the CSR. The 5 year warranty is only meant to cover the stove body as a welded unit. (I am assuming they mean frame only and nothing else.)
Now on the Warranty:
The Warranty (see attachment) this came with the stove. Look closely to the worded area relating to the 5 year aspect of the warranty against defects and workmanship on all steel parts. There is no listing for the steel brick panels or the steel baffle under the BURN GRATE since this is totally two different items within the stove box area. I would think that since the baffle and brick panels had to be manufactured, this would fall under: defects and workmanship on all steel parts. My back brick panel cracked in two places and the usage that I got out of them was just 2 months with the stoves operation on heat level # 3 and running on a T-stat set at 73* I have burned 31 lbs per 24hrs for the last 1 month. The stove would run a max of 32 minutes when called for heat.
Now look at paragraph #5.
All claims under this warranty must be …………..
Then way don’t these parts fall into this part of the warranty?
Now this how the CSR is explaining the warranty me, and what it really means. I see brick isn’t listed, but it has always been excluded in all three materials used over the last 25 years. I guess they overlooked the fact in the warranty that it is now made out of steel. The steel baffle is also not covered because they are parts that break down over time due to the heat in the burn chamber. The five year warranty is ment to cover the stove body as a welded unit.
They (CSR) is telling me that since other parts under the warranty aren't listed, such as the S.S.baffle and the S.S. brick back panel and sides they fall under the consumable parts and you have to foot the bill for replacements.
They have agreed to cover this under their warranty as a one-time replacement because it seemed to break down prematurely in my case.
Steve
Pheasant Hollow Farm
![[Hearth.com] St Croix Warranty Issues [Hearth.com] St Croix Warranty Issues](https://www.hearth.com/talk/data/attachments/150/150857-02d65a6946df8fe302b666f9abd6934a.jpg?hash=92Ln3tenQS)
Steve
Gasket being totally missing should be replaced as is a working issue IMO. The gasket is cheap, the labor is the expense.
