Been a while since I've been around but have a question I'd like some help with.
As you may recall, my backyard is really shady and as I learned this past winter, where I was stacking my wood is not going to work. Too much shade and not enough wind so even after 3 years, I had too many sizzlers and my glass would cloud up even with a perfect install.
I'm looking to put my 2015/16 wood in a different spot where it can be stacked single row. To do this, I've got 3'x3' pallets I would like to use in 2 10 pallet rows with 22" wood stacked in two rows on top of it.
My question is will, during the 4 years of drying, will the stacks begin to lean and fall over considering that the wood will be stacked to the outside of the pallet leaving 14" with no weight on it.
I'm concerned that over that much time, they will eventually begin to lean as the weight of the stacks pushes down, causing the stack to tip over.
![[Hearth.com] Stacking Question [Hearth.com] Stacking Question](https://www.hearth.com/talk/data/attachments/68/68591-f57922fa2e49828b629844177d3c32fe.jpg?hash=kSS4GRvmi7)
