I notice myself always staging up some wood for my next load ... and this morning had a though to build a box the exact specs of my firebox to stage properly and make better loading decisions. Anyone ever done this?
I carry wood to the stove in a tote. The tote holds the same amount of fuel as my firebox can fit. If it fits in the tote - it fits in the stove.
I hope you DON'T take this response as a mean-spirited put down - rather just some feedback from an experienced wood-burner.
I applaud your enthusiasm and proactive planning, but I don't think your idea is needed nor do I think it's likely to work that well. Here is why: Each piece of firewood is fairly unique in its shape. When you load a stove it's a bit like putting a jigsaw puzzle together. You might succeed in getting a nice compact assemblage of firewood in your staging box with all the pieces arranged upside down so that the pieces on top will load first and go in the bottom of your stove. However, each piece will need to be oriented exactly 180 degrees from its position in the box to replicate the arrangement inside the stove. That in itself is likely to be a challenge. Second, you will rarely have an empty stove to load unless you clean it out before each reload, which would be a waste of time and inhibit good burning since a stove burns better with hot coals and ash on the bottom. I've noticed that even a small 2" coal can cause a problem keeping a piece of wood from sitting the way you want it to inside the stove. Third, to get this precise arrangement in your staging box you will have to bring in some extra firewood so you can pick and choose from various size pieces to make this good fitting arrangement you're after. That will be one big mess if you are doing it in your house since firewood often has loose debris and bark that start falling off as you jostle it around. If you prep this staging box outside it's likely going to be rather heavy to transport into the house.
Most folks here at the forum will tell you it's really not rocket science to load a stove and after a short time of burning you get a pretty good feel of what pieces of wood will fit where in your stove to make a nice load. I wouldn't spend the time and energy on your project. I hope you don't take this response as a mean-spirited put down - rather just some feedback from an experienced wood-burner.
Thanks for the good proofreading Jags!
