steam shower
RustyShackleford
1,603
NC
We're thinking a steam shower would be nice. The master bathroom already has a 3x5ft walk-in shower. It's very dated and horribly. mildewed, so we're thinking of ripping that out. I'm thinking of a modular kit, for various reasons. For one, I don't have tile skills, but I can easily handle the electrical and plumbing for a kit. Also, we like the idea of high-quality acrylics and metal instead of tile - a more modern look, and probably better for mildew. It looks like a size that'd fit nicely into the space (after tearing out the existing shower) is fairly common. Here's one example:
... but there are many others available.
Does anyone have experience with these ? Other thoughts ?
I have no steam shower experience. But last year I ripped out a leaking jet tub and replaced it with a 3 piece modular shower. But the access path and room was so tight I had to hire a crew to do the actual install, because I could not handle the pieces. So measure the path to the install. cheers Doug
We have a Mr steam. Electric radiant floor and steam shower in the two most appreciated splurges on a big renovation.
Things to think about. Size. Our shower is 2x7 and we have a 9wk. It’s none to big takes about 10 minutes to get it warm. 4-5 minutes just to get water how enough to boil. We spent extra on the auto drain feature. 10 minutes after shut off it drains the water reservoir. We don’t use it a lot maybe 25-30 times a year. We have not descaled it. I should look at that. 5 years ago is had a clunky networking interface. I hope it’s better but I could use a phone app to turn it on and preheat it.
You will want seats don’t have the steam come out under the seat on your legs. The steam nozzle gets hot. Upgrade your exhaust fan and cut another inch off the doors that lead to the bathroom.
I descend to put the controls outside the shower. Even though it could have been installed in the shower. I go back and forth if that was the right call.
Temp sensor location is important. 24” and lower can be 80 while is 120 at the ceiling. The doors need to be really well sealed. Anything above the door should be repainted. The bathroom ceiling will probably get condensation near the shower door.
  • [Hearth.com] steam shower
So not a modular, but just added a steam generator to an existing shower ?
Correct. You and turn any room into a steam room!!
Yeah, we really want to ditch the existing shower, and the pre-fab seems a lot cheaper than a whole new tiled enclosure. Plus there's some anti-tile sentiment in our house - maybe the mildew thing, or "seems old-fashioned".
Looks like the 9kw unit is $4k. I see no reason it could not be installed in any pre manufactured shower. I’d run the steam line with cpvc so I didn’t have mess with soldering fittings in the new shower. A1/2” hole and your done!
When we were shopping the contractor really didn’t want a modular unit. It was a really big unknown to them. A lot of them seemed to good to be true! Where a large format tile shower could be custom sized and something they knew well.
Yeah, kinda looks like those modular units aren't so great. Think I'll build a new shower, go with one of the tile alternatives like cultured granite or marble, and a steam generator from MrSteam. Yours looks awesome !
That’s a good choice. It costs more but you get a shower that will lasts 40-60 years or more.
What you can’t tell is the ceiling is sloped to the back by at least 2” and it’s not quite enough but with grout lines nothing is. The thinking is so the condensation doesn’t drip on you. The temp probe location matters. Insulate everything you can. The doors matter a lot. They came in and laser and scanned the opening to get everything cut correctly. Were talking less than than and 1/8” tolerance. The swinging door seals the wall floor ceiling and other glass. Getting that opening built right is something that takes practice
Give some thought how to make it comfortable. You may want to spend 20, 30, 40?minutes in there. I didn’t. It still needs to function as a shower not just a sauna. I wish the granite seat could be heated.
Reactions: RustyShackleford
