Sthil chain sharpening
nsfd95
Burning Hunk
170
Eastern Long Island
Any suggestions for the angles when using an Oregon sharpener to sharpen a Stihl chain? Any help would be greatly appreciated.
30 to 35 degrees is a good guidline for general cutting. I think (off the top of my head) that most chains out of the box come at a 35 degree angle.....
Scotty , pretty sure that most stihl chain (at least rm & rs ) use a 30 * angle on the cutter with no offset from 90 * to the bar .
Could be wrong though , as i just learned from an earlier post that i have been " seasoning" wood all wrong , and will likely have to sell it for mulch . :)
You may very well be right. I usually just eyeball my Dremel up with the little pre-stamped 'line' in the top of the cutters......:p
Reactions: BobUrban
I was told 30 so I set my grinder to 30 degrees and it seems to work fine. Kind of a pain but if you remember to set it to a new chain before you put it on the saw you will always be duplicating the original angle.
Well, i cheated..... I read the spec sheet for one of my RS chains .........;)
Btw .... Is reading instructions still a man card violation ? :)
Reactions: n6crv and ScotO
Come on Nix - we play with chainsaws!! I even ask for directions now and then and I have no concerns for man card revocation!
Reactions: Nixon
Woah! You ask for directions ?! And, admit it ? I've got a long way to go then in my journey to enlightenment.
Just the other day , i picked up a cookie sheet fresh out of the oven . I immediately dropped it . Jan asked " did it burn you ?"
I said " nope , it just doesn't take me long to look at a cookie sheet " :)
Reactions: ailanthus and n6crv
Stihl Will have to look at the box later . Like i said , it might just be me but i like a 35 degree angle
Hey, that's all that counts in the end .
LOL what post was that? missed that one.
Ok, time again for this newbie to learn something...my Husky I know is 30...why would a Stihl be different?
Various chain manufactures call for different specs . It even varies by chain type . To specifically answer you question .....
I haven't a clue ! ;)
30/60/0 is pretty standard for most chain. That's what I default to when the chain type/specs are unknown.
Not to take this thread off course too far , buy MM where is the finish to the 460 thread ?
Great, thanks for all the tips. I have been fooling around with different angles just can't seem to find a set up that was giving a good edge. I can draw blood an an Oregon chain just by running your finger over it. That same angle on the stihl chain was just kinda blunt.
Don't forget the rakers . Their depth has ab great influence on the cut .
30/60/0 is about what I am going to use on some Stihl 26RSC72. Supposedly, it should be 30/60/10, but that 10 is really screwing me up when I try to line things up.
Think I read somewhere that you can go with 35 degrees for the soft stuff and 25 degrees for the hard stuff, but cannot remember where I read it. Thing is, you don't want to continue changing angles on the chain or you will be eating up metal.
I mess around on the old chains keep factory fresh for serious cutting.
MM where is the finish to the 460 thread ?​
It's coming. Package with the "finishing touch" is still on the way. Took it's damn sweet time getting here, and then showed up Postage Due. <>
That's ok tho, the seller will make it right.
Reactions: Nixon
