My new this year/season Quadrafire 4100-I Insert door latch seems to be "too" stiff.  I'm waiting for it to cool down so that I can give the door gasket a careful check....it may be out of the grove or otherwise making the door too thick.
The latch itself is a simple (pictures can be made if needed) that hooks a rotating pin in the case and pulls the door tight as one pushing the handle on the latch down.
The only adjustment is how loose the latch is on the door. That is one can't tighten the mounting bolt down to where the latch is hard to turn, or leave some clearance so that the latch rotates easily, but doesn't have a lot of side-play, that' show I have it adjusted.
In any case, it seems to be taking increasing pressure to rotate the latch into the locked position.
Any experience from other 4100-I owners would be helpful.
