For those of you who are using stoves sized to your home or who designed your home specifically for wood heat please bear with me this morning.
We woke up to minus 20 Celsius temperatures this morning and yes the house was pretty cool but we are agressively pursuing or own personal record for not using the furnace to heat our home yet this fall.
It's been a while since I have posted but a quick review is in order....
Our woodstove is a Drolet Jasper non-EPA that is apparently designed for 1200 square feet or less. It is in the basement.
We have an open fireplace on the main level that has a simple heat exchanger system with the two small fans, one on either side, that draw air through a set of tubes just above the firebox. Late last winter we installed a new "wall of fire" style grate that our son made in welding class.
While we are going through more wood than I would like we have been able to keep our 1400 square foot cedar log home warm through to this point in the season. In total we are heating 2800 square feet. Today is the first real test given the cold temperatures which are supposed to be with us through tomorrow midday.
We have been using a combination of fans to move the air through the house.
Our wood supply is the best quality and the highest volume that we have ever had to this point in our wood heat journey so we are not worried about running out this season.
As soon as the parts we have ordered arrive I will be finishing off the restoration of an older Regency 2000 that should increase our heating capacity substantially.
Some of the other things we are also using in our battle against our energy cost cash output are sealing up as many windows as is possible with shrink plastic, installing insulated drapery on our large set of South windows in our living room, and working to use our South windows as a passive solar system.
Still hoping for the day when our cash flow allows for the right insert in our fireplace so as to use wood more efficiently but for now, getting this late in our heating season without flipping the switch on the electric elements is, for our household, a significant victory.....
The nice part is, the forecast is for above freezing daytime temperatures for the next week....
