Hi All,
Having recently had a Stovax Stockton 5 fitted, we cannot seem to avoid the issue of smoke making its way into the room during reloading.
We are lighting it using a top down method with plenty of kiln dried softwood kindling and graduated oak splits with the largest being at the base. Everything starts great with very little smoke; the flue seems to draw well and everything gets up to temp nicely (flue at 230 to 250c) . We are burning air dried oak which is consistently testing at 19% MC on the face of a fresh split.
Having looked through this forum smoking when reloading does not seem to be an uncommon issue (perhaps due to eco stove design/baffle?) but we've tried the usual advice of opening a window in the room a crack and opening the air controls fully before reloading and opening stove door a crack (then slowly after a minute or so) but the smoke smell persists every time we open the door.
We have followed the manufacturers instructions of opening the airwash and secondary controls fully and waiting to the fire to burn down to embers but once the last of the flames has died, part of a spilt will often reignite as soon as the door is cracked, leading to us constantly waiting for the fire to burn out, at which point the flue temp is far lower (around 125c) which I'm thinking won't help the draw much. Another issue seems to be the inconsistency of how well the wood burns; ie when putting a new log/s on the embers the bottom of the log burns well but the top remains partially unburnt unless it's turned over midway, leading to smoke again when opening the door to turn it.
So far I've concluded that we'll either need to start reloading whilst the fire/flue is still hot and has better draw or keep experimenting with log positioning in the stove to ensure more even burn/airflow. I have already been mixing in softwood with the oak and this seems to help somewhat perhaps we should start adding kindling on top of the logs when reloading to assist with an even top and bottom burn?
Anyway, I'll leave it there and hope someone can help their insight/experience on how/whether this can be resolved?
Cheers.
Cheers.
