I am trying to work out the logistics of installing my very first wood stove in a shop (barn) I had built in my back yard, and I have a couple of basic questions. First off, the shop has significant "vaulted" ceiling space, so I'll need at least 13' of stove pipe to travel from the stove to the chimney box.
1) Since there are clearance concerns regarding the use of stove pipe being too close to combustibles, I wonder if it is OK to connect double-wall stove pipe to regular single-wall pipe, where needed? My thinking is that where the pipe passes a roof truss (combustible) it could be double wall as required, but when the pipe is climbing through open air space, it could be the less expensive single wall pipe.
2) Is a standard drywaled wall considered combustible? That is to say, how close can a stove be positioned next to a wall if it is constructed of the usual 2x4 studs, fiberglass insulation and sheathed in half inch drywall? I suppose there are local city codes regarding this...or perhaps a minimum distance provided by the stove manufacturer...or both?
THANKS
THANKS
