Hello! This is my first post, but I've already learned a lot by reading through these forums.
I'm building an ICF house on the Colorado Front Range, and I'm looking for a recommendation. The style of the house and roof pitch leave me preferring a 13-14' chimney height (from top of stove...15-16' from hearth floor), but it will be a straight up, insulated double wall pipe. I'll also have an OAK due to the very tight construction. The house is at about 6,000', so I think I'm going to need an easier breathing stove if I'm not willing to put in a taller pipe.
The house will be a ranch with a walkout basement (~1700 sq. ft. up and same sq. ft. down), but I'll also have central HVAC with separate zones for upstairs and downstairs. My main goal is to primarily heat the main level, which has an open floor plan, with the stove.
My priorities:
Also, keep in mind that ICF houses and very, very tight and well-insulated, so I need less stove than most would for 1700 sq. ft.
Btw, I plan to process my own wood, and I'll be burning mostly softwoods. Thanks in advance for all your help.
My priorities:
- Good burn time
- Modern aesthetic and good viewing window
- Work well with 13-14' straight chimney @ 6,000'
