We are adding a room over our garage that will be used as an office as well as there will be a walkin storage area in the rear.
The office area is roughly 16x28 or approx. 450 sq ft.
We are not going to run heat into it from the furnace as we don't usually use the furnace for heat as we have 2 pellet stoves that heat the home.
So to get heat into the room we are looking at the Jotul GF 300 DV Allagash stove w/the optional blower unit and wall mounted thermostat.
Seems like it should be plenty of heat for the intended area. Would probably leave it set at about 45 during the colder Winter months. When the wife is going to use it she'll just crank It up to 68-70 and should be good to go in about 1/2 hour or so. I think. LOL
My biggest question is the choice.
Is this a good stove? What do most consider the best gas stove? Etc etc.
The place that sells the Jotul stoves also sells Vt Castings and Hearthstone.
He recommends and his opinion is that the Jotul is the better of the 3.
Oh yea, another ?. Best to vent out the roof, the wall, not matter? I like the idea of the look through the roof. Any problems with that option?
So what say all you gassers.
Thanks for any and all help.
