Hello! I'm an old woodburner finally needing to replace my Consolidated Dutchwest Large Federal catalytic (circa 1987, if memory serves) with something newer. The old (about 150 years) part of my house is approximately 850 square feet with low ceilings and is leaky as all get-out, while the newer (about 25 years) part covers about 400 square feet with larger rooms and cathedral ceilings and is substiantially tighter. The stove is located in a 13' x 13' room in the old part that is central to that old part and connected to the new by a formerly exterior window that has been left open for circulation. The chimney set-up is through-the-wall into a mostly exterior masonry chimney with a 6" liner. My budget ($1500 - $1600) will not cover another cat stove, which would be my preference for longer burn times, so I'm looking at non-cats. My dilemma is whether to go with a "small" stove (1.4 - 1.6 firebox) or a medium one (around 2.0 - 2.2). It's a dilemma because I don't know if going with the larger size stoves will necessarily create more creosote in the chimney on overnight burns or in mild weather because of burning cooler than smaller stoves, or if it's just a matter of maintaining a given temperature and getting longer burns in the larger stoves. Back in the day, the thinking used to be smaller stove = hotter fire = less creosote, but I don't know if that still applies in today's brave new world of wood burning. Plus, I would rather not be heat-blasted out of the stove room (at least, any more than I'm used to with the old Dutchwest!). Any input will be greatly appreciated! Thanks, Brad
I guess my memory is lapsing. Then the PE Super would probably be the better choice. I have the insert and can wholeheartedly recommend it.
