thinkxingu said:
Hello There,
My Englander 13, which we use for supplemental/periodic heating on weekends or during mass power outages, is in the bottom of our split-level. After use, when the coals have cooled down throughout the night, I shut the air control. Afterward, however, I notice that I get a strong burning wood smell, which is stronger than when it is actually in use. Any ideas on why this occurs or what I can do to prevent it?
Thanks,
SML
After use, dont shut down the air control.
A secondary burn englander stove is not airtight and it needs a more open primary air control to exhaust fumes from smoldering coals.
On the surface, it may look to you that all the coals are out, but under a layer of white ash there are still small coals burning , making the camp fire smell . The very low heat of a
nearly dead coal bed lowers the draft from the stove pipe (draft over fire) and so it becomes rather hard for the stove to exhaust cold burning fumes especially with a closed primary aie intake.
Also, the primary air intake can never be completely closed airtight, but only closed 80 % as there is a factory stop that prevents it from total closure.
This opening is not enough to provide enough intake air to vent the fumes but is enough to let the fumes into the room, especially if you have a low draft short chimney that only works well when it is hot.
That is why people say light a twist of newspaper in the stove to get the draft working.
I have a 48 foot chimney and on certain days even I have no draft & have to heat up the chimney with newspaper to establish a draft. However, on some days I have so much draft that it blows out the match on me & I can't light the newspaper to start the fire.
So try leaving the primary air intake wide open after the fire is out & see if you still get the oder.
Also, try raking the coal bed with a small hoe to see if I am right about their still being some live coals under the ash.
