You can do what you want but if it really was an issue don't you think the manufacturers would warn customers and dealers?Flush mount with a cat running at 1500 degrees, you can do what you want but I would be pulling the surround.
I pull my surround about an inch away from the brick facade of the fireplace. When I'm running the unit 24/7, I can feel heat pouring out of that little slot into the room. As others have said, it may eventually make its way into the room anyway, but I like to run it this way.
Hey edge of the woods...this question is a bit off topic but I noticed your insert surround almost touches what looks like wood trim around the fireplace. I have a Regency/Hampton HI300 insert in my fireplace and although it meets all minimum clearances to the wood facing & mantel (double checked by the dealer as well)...I sometimes get a little nervous during long burns when the wood facing feels really hot to the touch. But I have about 4.5 inches from the top of my cast iron surround to the 1/2 inch wood facing...looks like your metal surround is almost touching the wood trim...ever had any concerns with that? P.S. My wife would have never allowed the insert if I had to remove the very elegant mantel and wood trim around the fireplaceSo I had the insert out the other day to see how easy it would be to put in a block-off plate. Took a couple pics. Check out the insert with the surround off, compared to the pic of it burning tonight (first burn this year).
View attachment 164476 View attachment 164477
Now the surround gets pretty hot to the touch, too hot to keep your hand on for more than a two-count. Here's my question:
Is the surround costing us heat, by keeping hotter air trapped behind it? Is that something the block plate will totally fix, or would I get some more heat out of the insert by putting some holes in the surround in a few places with a 1" spade bit? Is that insane/dangerous?
It just seems like even if a block-off plate was in, there would still be a lot of hot air that's not moving out into the room. Why isn't the surround more of a grate than a solid piece?
Thanks!
Dealer installed with no permit or advice to you to get permit??Not yet, town doesn't have the permit on file for the install, applying for a new one. Once the install is signed off on, I'll do the plate, and will update!
I don't know. I vacuum back there when I clean the chimney. I'm not sure if it's building up or just kind been there. Sorry. Not much help.Any issue with dust/hair getting back there? When I pulled our surround the first time, there were some small dog-hair dustbunnies inside the fireplace cavity with the stove. Not sure if they got trapped when the insert was installed, or developed since then.
Dang fine way of accessorizing!
Hey edge of the woods...this question is a bit off topic but I noticed your insert surround almost touches what looks like wood trim around the fireplace. I have a Regency/Hampton HI300 insert in my fireplace and although it meets all minimum clearances to the wood facing & mantel (double checked by the dealer as well)...I sometimes get a little nervous during long burns when the wood facing feels really hot to the touch. But I have about 4.5 inches from the top of my cast iron surround to the 1/2 inch wood facing...looks like your metal surround is almost touching the wood trim...ever had any concerns with that? P.S. My wife would have never allowed the insert if I had to remove the very elegant mantel and wood trim around the fireplace![]()
That is beautiful!! I love the animal accents, very nice touch. What did you use to paint it? Did you weld it yourself? I don't have access to welding equipment, but figure I can bolt some mesh to a steel frame that I bolt together.
