Tonight I had to sweat a ball valve and while doing so I came up with a question I'd like to resolve for the future.
The ball valve was in a vertical position. I needed to sweat a fitting onto the top of the ball valve. I got to thinking that it could be a problem if I put too much solder on and it ran down into the ball area. I ended up flipping the ball valve over (end-for-end) and sweating the "top" while it was under the valve. I let it cool, then flipped it back over and sweated the fitting in the bottom. The idea being gravity wouldn't cause solder to flow towards the ball.
Would it have been a problem had I sweated the top fitting while the valve was vertical and the fitting was sitting on the top? Can solder cause the ball valve not to seal if solder runs onto the ball? Is there any plastic (as a seal) anywhere near the ball that would melt if I got it too hot or is the entire valve made out of metal?
