We moved into our first house that has a woodburning fireplace upstairs on the main floor, and an old woodstove (1975ish? when the house was built) downstairs in the finished basement (second living room/office, bar, laundry, bedroom, full bath). The fireplace upstairs was gas when we moved in, and we got it capped off and switched to a woodburning fireplace. The gas co. worker who came out said the gas fireplace had never been used, not even once. Weird.
Anyways, our first 2 loads of logs from Craigslist were a mix of softwood and harwood, but mostly softwood. I've been researching to figure out what types of woods to avoid, and what types are the best. Everything I've read points to hardwood being better in the long run, yet slightly more expensive, and more difficult to get your hands on. The softwood mix burned hot, and probably burned faster than what I'm reading about hardwood, but it was enough to heat up the entire 2800 sq ft home. We mainly use the woodstove, since the heat in the fireplace goes up and not really out into the room. The woodstove is located downstairs at one end of the house, but the heat travels upstairs and all the way down to the other end.
This weekend we ran out of the softwood mix and got a load of mostly seasoned hardwood mix (to include cedar, maple, dogwood, fir, etc.). I'm not sure if I'm doing something wrong, but when you put the logs on a hot, well-burning fire, it almost puts the fire out. With the softwood of the previous 2 loads, I could put any amount of logs on the fire and this never happened. It would keep burning hot and get even hotter the more wood you load in the woodstove. But with this hardwood, it seems like tossing on a few logs puts the fire out. If you only throw in one log at a time, it certainly won't heat up the house. Right now, no matter what I do, it barely heats up the room, much less the house. With the softwood, I could get it burning so hot that it was too hot to even sit in that room.
So, what should I do? I'm obviously doing something wrong, or there's more info I need to know about these new types of wood I'm trying to burn.
Thanks in advance!
Thanks in advance!
