Nope.Wont filling a firebox to capacity and slowing the combustion lead to toxic emissions and high creosote?
As long as you don't turn it so low as to kill the re-burn, no. Most secondary burn stoves are designed to keep re-burning the smoke even at the lowest air setting. You can stall a cat stove if you turn it too low, too soon.Wont filling a firebox to capacity and slowing the combustion lead to toxic emissions and high creosote?
No one here has mentioned dry wood. The way to get long clean burns is to choke that air down. Can't do that with either a cat or tube stove unless that wood is dry.
Yes to big splits. Love em. Take longer to dry completely though.
Pretty easily I did it with absolutely every load in my regency.I only use old cast iron stoves. I still dont' understand how one gets 1100+ Degrees for secondary burns with a dampened and packed stove.
EPA stoves are designed to work that way. The secondary air on a tube stove is never fully shut off.I only use old cast iron stoves. I still dont' understand how one gets 1100+ Degrees for secondary burns with a dampened and packed stove.
...what is it?
N/S or E/W?
Smaller splits on the bottom, with larger on the top or vice versa?
How much of the wood should be charred before closing down the air? Is it ok to say, only have the fire going on one side of the stove or say only the front or back, and let the fire carry itself through the wood with time.
Sometimes when loading only part of the wood takes off, I cut the air and start getting secondaries from the fire in that area but then another area of wood is just smoking with no primary flame. Is this ok? I find if I let too much of the wood get started/charred, the stove takes off and gets too hot.
In the old smoke-blower stoves, you pretty much have to have flames in the box to get any semblance of a clean burn; You can't cut the air back and burn clean with 'em.I only use old cast iron stoves. I still dont' understand how one gets 1100+ Degrees for secondary burns with a dampened and packed stove.
There were old cast iron stove designs that had simple secondary combustion systems. Our Jotul 602 does this by introducing air at the point where the smoke wraps around the baffle and reverses direction. The original Vermont Castings stoves had a more sophisticated secondary burn system as did the original Hearthstone H1.
