Yeah, at the stove shop, the Plain Jane like mine was $3000, but with gold was $3300+...can't remember if it had the bay window trim and the ash lip trim.I think it would be a strange install to just pipe it to the liner? I dont know what would hold it in place?
Also i have the gold door and windows. We did not think we would like it at first. Wife hates gold/brass. I does look sharp though. And its real gold leaf as well, better than brass as you dont have to polish it. I think it adds hundreds to the price of the stove when new. I think Stoll quit making the gold door but when i bought mine the company still made then then and i think my stove as it sits was sold in the showroom for a bit over $2500!!
If you don't have a lot of pipe/liner, just the screws would hold it I would think...
Here's how I understand the connections (I've been known to be wrong
Positive, Direct, Slammer.
Sounds like you have this one that is shown in the manual (shows it on a free-stander, but...)Woody,
mine has a large heavy duty cast, if I remember correctly, connector and gasket that fits flush to the top of the stove.
It connects with 3 L brackets that are inside of the connector down inside the stove and out of sight. Good looking fit.
My bay windows blackened up the first fire and have been that way ever since. I tried to clean them but they are a b#*$% to get to....lol.
My cat temps will exceed 2000 degrees but the Buck rep guy @ Bucks plant told me not to worry that they were good at far greater temp than that......now I just let her eat.
David
"optional NBC cast chimney connector"
Finally figured out, NBC=New Buck Corp.
[Having trouble pasting image] Pg. 17 of online manual.
(broken link removed to http://www.buckstove.com/buckfiles/manuals/Buck-Stove-Model-91-Manual-%28Rev-10102008%29.pdf)
When I saw the stove for the first time I noticed that the front window was clear, but the bays barely transmitted light...figured that was the way it was going to be (which is too bad because seeing the fire from the side would be cool.) I guess that besides no air wash, there's probably not enough radiant heat in those corners to keep 'em clean...
As far as the combustor temps, I'm going to try to keep them below 1800 but several owners have said that it will go to the moon pretty easily. I'm going to try to control off-gassing by using big splits, loading methods, air control etc.
Well, I finally got back over there and chopped and trimmed the brick out of the back with hammer, chisel and masonry wheel on an angle grinder, and also got some of the creosote out of the smoke chamber of the masonry chimney. It was pretty rough. I had to fashion a booth out of a bed sheet taped to the fireplace to contain the dust. I put a box fan in a window to try to force air up the chimney faster. That kind of worked but I ate a lot of dust, even with the mask and glasses. I was going to cut a sealing strip for the mask out of my goatee, but in the end didn't go that route.
I went after the creo with a cable-tie wire wheel, up to the level where I will install the Roxul "block-off plate." If I had it to do again I would just knock off the flaky stuff with a wire brush; There was so much creo dust that I thought it would get sucked into the grinder and I would have a tool fire on my hands.
Tried to call Buck yesterday to get some answers on these parts, but no answer. Will try again today.
We have a couple of days in the upper 70s to begin next week, and not too bad after that. I should have this torch installed by the time some cool days get here...
