The wood shed is getting empty...
SWNH
310
New Hampshire, USA
It holds about 6 1/2 cord. This is all that is left for the rest of the burning season. Of course, it's almost all that EVIL pine. Still have plenty of outside stacks for another 2 years.
However, my neighbor down the road is clear cutting a house lot for his son asked if I wanted the pine trees. He has an OWB but doesn't like to burn pine. So much the better for me! After checking out the site, I found that more than half the logs are saw quality logs. Nice and straight with few branches. They were already cut to 12ft and stacked. The mill on it's trailer can handle 9ft lengths, so I lopped off 3ft from all the logs (more burning wood).
It's about 1/2 mile up the road, so the challenge was to get the logs to my place. Skidding was out of the question because it would damage the dirt road. So I got a small log arch that is perfect for the job. It's also small enough for maneuvering on the tight trails of my property should I decide to take a log for sawing instead of burning. I replaced the hand winch with a 12v electric winch and replaced the standard bearings with tapered wheel bearings since they did not hold up to 20mph loaded speeds. Other than that, I find the arch works great. It can handle 16" diameter logs which is the limit of my mill anyway.
I estimate I can recover about 8 cord of burning wood at least a couple dozen saw logs. The ironic part is I'm probably going to use the lumber to build another wood shed! Does this wood addiction ever end?!
  • [Hearth.com] The wood shed is getting empty...
Great equipment & set up.
I'm burning "evil pine" (spruce) now. Burning great.
That's a "triple score" : fire wood, logs for milling & lumber for a wood shed :)
8 cords to CSS. 24 logs to mill. Wood shed to build. You are going to be busy & make allot of saw dust.
Sounds like you are having fun :)
Looks great SWNH + I like the log carrier for the ATV - how much did that run you? Cheers from Rindge!
About $800 shipped from American Bandsaw Company. Since I only want to fetch logs for the maximum size for my mill (16" diameter), all other models (from them and others) were too big/wide for my use. For firewood, I cut to length in the woods and haul out in the ATV bed.
Not too bad - thanks!
That's a great find SWNH. I'll bet the neighbor was really happy to get rid of that awful pine stuff too. lol
