All,
I'm just wondering if someone knows the answer to this: is the BK thermostat limited (by design or construction) in any way regarding opening the flapper?
Now that it's cold outside and I need some more heat output from the stove, I notice that with the knob set at around 4 o'clock (6 o'clock being wide open) I get a nice and steady heat output exactly the way it should be as long as unburnt wood is in the stove. When that's gone and only coals are left, the heat output drops considerably.
However, by turning the thermostat to wide open in this situation, I'm able to get the heat output back up to the previous level by burning down the coals.
So my question is: is it just that the thermostat is not able to open the flapper completely when the knob is at 4 o'clock? I.e., by turning the knob to WOT I'm giving the thermostat that range of movement back to open fully? @BKVP, is that the case?
If it's not and the thermostat is functioning correctly, it should be able to maintain stove temperature and heat output even with only coals left (at least until the flapper is wide open).
Thx!
Thx!
