Thinking about 2nd Stove Install...
dmmoss51
355
Michigan
Ok So after seeing some of the cool installs and hearths that have been posted on here I think this would be a really neat project.
I have a 1800 sq ft home its a split level - counting unfinished basement there are 4 floors half a floor up from each other... maybe I can add a diagram or a picture later.
My current stove is in a family room on the second floor from the bottom, half a floor below the ground level and a story directly below the top level which is where the beds are. It is nice and open from that floor up to the main level where it is living room dining room and kitchen also very open.
The current stove location does a good job of heating the whole house do to its location and the opening between the floors. So this would be to add some additional but nut necessary heat and especially aesthetics.
I would like to DIY it. I have a trades and woodworking background, I've done other diy repair projects. Framing drywall roofing all OK in my book. I know I am going to have to build a hearth with proper clearences etc and run Class A chimney up throgh the ceiling and atic. My main question is anyone know (especially for Michigan) the process for permitting inspecting etc? I am assuming you can't just thow this together and run with it without having some trouble if discovered by authority or for resale issues.
On a side note I might eithr add it to the living room or as part of a larger project I am thinking enclosing a 12X12 sun room on what is now a concrete patio with french doors to the dining room. It's a dream stage right now for sure.
Why not just pull a permit? Code varies by municipality in NY, I imagine it's the same in MI. There are very few things that a homeowner isn't allowed to DIY here (furnace install was one-you can't even buy a furnace here, like at the Home Depot or something). I'd make sure it was a permitted install anyway, especially for insurance reasons. Don't give them any reason to deny a claim (if you were to need to make one)! Our inspector just made sure the stove was installed per the mfg's clearance, etc requirements (it was done by a hearth shop, but he said it would have been the same if we did it).
I would definitely pull a permit I just wondered if anyone had been through the process recently and new when to start... I haven't even selected stove or location so I supposed that leaves too many things open to be formal with it yet but if I find out it's something I absolutely can't do well then I can stop dreaming ha.
I can't speak for MI, but here it was our building inspector. Start with your town/city/village building department. Ours is a super great guy, very easy to work with and helpful. The guy where our Old House is, he was a nightmare, never wanted to answer a question (well, the second guy since we bought that house, the original guy was pretty good too-luckily we did most of the work there while the original guy was there).
Might have a problem with that unless you've got compliant footings below the frost line under the patio (not normally the case with a patio).
This is true... may change on what it now to where there is now :p
