A little history...
Back when we first moved in, this place came with radiant (coils in the ceiling) for heat. It was incredibly inefficient and would be close to $1000/mo. just to heat this place (2000sq.ft. colonial). So I initially called the gas company and asked how much it would be to connect us. I was told that if we were going with a gas furnace $300. Ok, not bad. If we were NOT going with a gas furnace...$3000! Ok, thanks, bye!
So after doing a bunch of homework I decided on a VC Encore 2-in-1 wood stove. Well it's been a royal pain in the ass for us. Between hauling in wood, arranging drop offs and testing the wood, sweeping the chimney, replacing the gaskets, etc...etc...etc....
At this point I'm considering giving gas another try. I'd probably just fib to the gas company about the furnace. I mean technically we ARE going to be using gas to heat our home. But I'm not sure how they'd verify whether we actually go with a furnace or not.
But I figure since we already have the hearth, the chimney, etc...maybe we could look for a gas stove that will heat the home the same but with a flick of a switch/thermostat instead of all the cost/labor we have to do now.
How's my line of thinking? Realistic? Is gas significantly cheaper than wood ($200/cord)? What stoves should we look at? Is used ok? Money is VERY VERY tight right now.
Thanks
-Emt1581
Thanks
-Emt1581
