Gasifier
I made some adjustments to the cycle timer. Now I have it set for 2 trips (~4 mins) every hour. I lost fire yesterday at some point so I made the adjustment.
Overslept a bit this morning and woke up to a cold boiler. Started a fire and warmed it up. Apparently on the next automatic restart attempt we had a pretty good puff back. Got the smoke detectors going and the dog freaked out.
Has anyone piped their intake outside? Do I have to come DOWN 24" on the intake before heading outside? Ideally I would be able to stay up high and run along the ceiling outside.
ac
I have not piped my intake outside. If it is in your basement I would leave it drawing air in from there. I would not want cold air from outside coming into the boiler when it is really cold outside. I think it would be better for your 60ish air in the basement to be taken into the boiler.
As far as a cold boiler goes. I have had an occasional "bridging effect" because of a larger split holding up the other wood and the coals burning right out from underneath it. You have to watch out for that as well.
 This is true. I wasn't thinking about that. LOL. After some trial and error and talking to other Wood Gun owners in the boiler room I found that having my damper closed almost all the way prevents almost all puffing. If I get some really dry wood in there, or their was more wood than necessary in there that dried out and the boiler went into idle then I may get a puffing when it lights up. But it is really rare now. How is that cycle timer working? I am curious as to why you are still getting that smell. Is that just from the puffing you had? Or are you getting a creosote kind of smell? Your wood is certainly dry enough. Most of my wood is from 17 - 22%, roughly.
 With only a little over one full year with the boiler, I am still learning as well.
