For some time I've been looking to add a wood stove or pellet back to my sun room. Originally I had an over-sized Jotul Model Number 1 that tended to drive you out of this 12x14 room. I have a chimney that is up to code ready to accept a new stove, and adding an air intake to the room for a pellet stove will be easy.
I recently came across what looks like a good deal on a Breckwell 1995/1996 model year P24FSA for $500. Assuming the stove works I have a few concerns:
1. The specs list this stove at max 50K BTU output, whereas my sun room auxiliary heat is an electric baseboard heater 2500/3000W producing around 8.5-10K BTU. On its lowest setting the Breckwell manual says its feed rate is 0.75 to 1.5 lbs/hour. My first question is can this stove be throttled down to not drive us out of this room? The room is well insulated but has significant heat loss due to many windows, a door, on a slab and insulated cathedral ceiling.
2. The seller does not have the stove hooked up and so there is no way to verify full opeation. What can I check to be reasonably sure the unit is working, or at least I won't have to replace an expensive part?
3. Are there any other issues I've overlooks as I have never owned a pellet stoves and don't want to make any costly mistakes here.
Thanks for the help.
