Hi All!,
First timer here... Seeking opinions on which direction I should go. I have an existing fireplace with an existing propane gas line coming in. Fireplace currently has no cap on it and the throat damper is missing the plate. I guess I have two possible directions: 1) Put a mesh cap on the top of the chimney and try and install a new plate (looks like the infrastructure of the throat damper is OK - just missing the plate and the handle) or 2) Install a top lock chimney cap... Our heating fuel is propane so the fireplace gas line is already tied into it and would like to continue to use it. Previous owners took their gas fireplace insert but cannot afford a new one at this point. Was thinking of just putting in a vent-free gas fireplace log set. Much cheaper solution but I do have a small concern about leaving the chimney open (i.e. no throat damper plate) if I go the top lock chimney cap direction. Will I lose all the heat from the gas log set? Any opinions are welcome! Thanks all
