Good morning guys. I'm replacing my woodstove; going from the VC Defiant 8" pipe to PE T5 6" pipe.
The horizontal through the wall flue pipe to the chimney is 7" in diameter, and 18" long. It is in two pieces, first a 6" long piece then a 12" long piece. They do not meet up flush; they are off by a hair or two. No cracks or gaps. My point being, I couldn't shove a 18" long 7" diameter pipe inside it, all the way through, due to this slight offset. Chimney is 7" as well.
What would be the preferred connection for my new 6" stove pipe?
1) Get a 6" to 7" adapter, install it at the wall, and push the 7" pipe into the flue as far as it can go?
or
2)Run the 6" stove pipe all the way through to the chimney, and insulate around it?
or
