Help understanding draft and brainstorming options on a super tight budget.
DandelionMama
3
Maine USA
Hello I'm new here. I have built myself a little cabin, 14x24 and my dad brought me a small woodstove up from the basement of his camp a few weeks ago (I need to uncover it from its tight wrappings and get the name and number for you tomorrow). But it has been cold as February up here in downeast Maine--and my insulated cabin has been only heated by a tiny electric space heater and some mornings it has been 34 degrees indoor for me and my 7 year old boy! So I've been super eager to hook the woodstove up and I went to Facebook marketplace and found a screaming deal on a whole through-the roof kit plus 9 feet of DuraVent for $350! I wrote to the person about my situation and despite what she said was "hundreds" of inquiries on the pipe she chose to sell it to me. It is barely used!!! In mint condition. The only problem? It is 8inch diameter pipe and the stove is small and has a 6 inch output. The system did come with a diameter reducer piece but I excitedly mentioned my score to some guy friends of mine and they all were really incredulous about this pipe being usable for the little stove. Not enough draft. My dad (by no means an expert) suggested running 6 inch single wall up through the 8 inch insulated to create less air space and hopefully encourage draft??? And save money??? Advice?
Sincerely, broke before Christmas and extremely cold in Maine--desperate to safely connect this woodstove!
Resale and get the correct kit. Understand the tight budget. I'm currently on one myself.
I believe your 6'' flued stove will behave correctly with the right sized flue. Running 6'' stove pipe up the 8'' chimney may not be a good idea.
Reactions: stoveliker
I agree. Resell and get a 6" set.
Exhausting in a wider flue will slow down and cool down gases leading to creosote deposits. You don't want to deal with a cabin fire on top of what life brought you.
If you install the 8” and it doesn’t work, you’ll have to either swap it out or find a stove designed for 8” pipe. There are some of those, but far fewer of them.
People have probably explained it to you already, but what happens is that at the transition from 6” to 8” the pressure and temperature of the exhaust gas drops quite a lot as the gas has to expand into a much greater area and volume. That means the colder smoke has less tendency to rise, and also colder smoke can condense more creosote. So it really is potentially bad trouble.
IDK about your dad’s idea. I’m guessing at minimum it wouldn’t pass code/insurance scrutiny if any of that came up.
Is your wood put up yet?
It’ll be hard to find dry wood at this time of year. There are work around, but they aren’t easy/cheap. I don’t want you to spend a lot of money on a stove that is hard to use due to wet wood.
I suppose it’s best to find out what stove you have first.
So the big mistake here is..
Figure out what stove you have. Fined the manual for it and look up the requirements for the stove pipe and all the clearances.
Read the manual it tells you everything
It's a Reginald 101 so similar to a Jotul 602
Thank you for redirecting me to be self sufficient and not ask for brainstorming help from experienced folks which probably seems silly to you all! Will take myself to Google and look up the manual--
Long story--I have a family compound with a few small buildings. The main house (660 sq feet) has been burning wood for a while so my kids and I have a few cords put up that would be enough for the two buildings for the season. My new 350 sq ft cabin next door is the one without heat currently. It's. Reginald 101 in good shape. Similar to a Jotul 602
I believe the 602 came with a 5” flue collar. Many run it with a 6” flue. 8” is way too big!
Have you located a manual? The reason we ask is that there are so many different stoves around that usually the manual is usually the go-to.
This stove is very similar to the Waterford 101. Most of these stoves in Europe are on 120mm flue systems. That's like 4.7" and works with 5" flue pipe. Jumping up to 8" would be too much. Measure the flue collar without any adapter. If it's 5" then use that for the stove pipe and chimney pipe. It should be less expensive. Otherwise 6" can be used, with an adapter.
You mentioned a cabin, is the Reginald going to vent vertically through the roof? If so, will you have chimney connector pipe going up to a cathedral ceiling? I say this because if total vertical, 6 inch black pipe going up a bit, transitioning to 8" at the support box of Class A, that all might draft ok. I'd try that if all you can scrape together is using what you have, but if buying 6" Class A components are achievable, of course that would be the better choice to do. Ensure good dry seasoned wood is used, if not, it won't matter what size chimney, it won't work out well... Always liked the Reginalds too. (Try) to stay warm.
If you are on a really tight budget and don't have wood that has been drying for multiple years already lined up it may be best to invest your time money and energy into a vented propane heater for your size building. Emphasis on vented but you can get into one of them very reasonably and then you always have backup heat.
