Through-wall fans to distribute heat from wood stove into adjoining rooms
inthecountry
4
Mendocino, CA
I live in a cold climate in a small house with no central heating or duct work. A Blaze King Ashford in the livingroom generates plenty of heat. I think I could warm two of the bedrooms with ducting with integrated two-way fans connecting the livingroom to two adjoining bedrooms. Ideally the system would be smart and controlled by an app and responsive to thermostats in all three rooms. Has anyone seen a setup like this or an alternative approach to accomplish the same result?
Used a few of these for a awhile. You should be able setup a IOT plug to turn it off and on based off of a IOT temperature sensor in the room.
Try moving the cold air to the furnace as well
Reactions: ewdudley
I don’t have a furnace, but I guess the principle is moving cold air out of a room rather than trying to get warm air in?
Yes, much easier to move the cold air towards the stove, creating a convection loop.
