Hello all, I have a woodstove in my basement, has 8" pipe going to an 8" round thimble in the concrete basement wall. From there it goes up the chimney,which is lined with 8" round clay flues.I would like to install a stainless steel flexible liner but am torn over whether to insulate or not. As it is, I am guessing that a 7" ss liner will be used, as anything larger will be quite the challenge to stuff down the chimney { such as a 7.5" liner, and obviously 8" is too big }. That said, if I insulate around a 7" liner and then try to stuff down the chimney...well, things might be a little too tight. I have been using the woodstove for years w/o a ss liner and the draft is great and I clean 3 times per season. { I burn wood daily }
