Any performance differences between top and rear flue exit on Hearthstone stoves? Have used both configurations on dutchwest and vermont casting stoves in past.
I've got a rear exit, but also a very tall chimney. The upside is that I don't have a tall pipe going through my ceiling/roof, but I also don't get the extra heat radiation of the longer pipe provides.
stove is a castleton by hearthstone. hooking up to a 20' chimney through a fireplace. rear would make connections easier but vertical is still possible as it is a large fireplace opening.
flue setup is already in place with great results and draft. Hearthstone is replacing a small vermont casting aspen that is inset inside the fireplace. Am hoping to pull the new stove out onto the hearth for asthetics and more radiant heat. just hoping the rear exit will not diminish performance.
