TOP TIP - Stretching Your Firewood Supply
MikoDel
Every year I learn something new. (Well, I guess I can even try for every hour of every day!) But with respect to wood heat I can usually pass along one or two new useful tips every season.
This is a really good one...
How do you stretch your firewood supply and at the same time maintain a truly comfortable temperature? (as opposed to GOD I FEEL LIKE I'M ON A SHIP IN CLOSE ORBIT AROUND THE SUN!!!)
Here it is:
Gather and save MUCH MORE dry kindling than you think you need. And use it several times a day.
If you're like me, not all of your wood is perfectly seasoned. Which means, you might not always have a small enough, and dry enough split on hand that will catch if you let the embers get really low. So what do we do? We STOKE!!! When the stove has red hot coals, we stoke. It's a GUARANTEE that there will be no headaches starting the new load.
But with a cast iron (or soapstone) stove, that's not always necessary. Unless the room is unGodly cold, I let my VC Intrepid burn down to where I can barely see a glow thru the glass. The room and 1st level of the house is still comfortable, especially if the stove has been going for a few hours. I keep kindling indoors, at the ready. To start the initial fire in a cold stove, I go with a bunch big enough that I need two hands to hold it.
But when I restart, I can use less. I toss that on the dying ember, maybe even with some paper, then a few small splits and broken pieces, and in no time there's a fire again and my splits are becoming involved. Without the kindling, even if I have cardboard, it can be much more of a hit and miss deal. As I said, my wood is not always perfectly seasoned. If your splits are really dry, you can probably get away without using kindling and get them going with only cardboard and paper. But dry twigs provide the extra BTU's needed to get slightly under-seasoned wood to catch.
So gather your kindling, and keep a lot handy. Instead of stoking when your stove is still really hot, let the heat life of the material work for you. Catch the coals during their last gasp. As long as the firebox is warm and you have twigs, you will get a roar going again directly.
  • TOP TIP - Stretching Your Firewood Supply
I dislike kindling, and I have the scar on my hand to prove it. Lol.
I use wood shed floor bark/wood chunks/wood garbage to boost the coals if I forgot to keep up. That, and homemade fire starters.
With dry wood and and 24/7 burning no kindling necessary. The new load fires up quickly. But a good supply of kindling is nice for shoulder season burning. Cabinetry and unfinished flooring scraps work great. I also get a fair amount in splitter fragments, especially with doug fir.
Reactions: jeffesonm
The splitting fragments, woodpile gold!
I've never lit a fire with anything other than scraps/kindling. I usually keep a nice stash of cedar for kindling. Easy splitting and easy lighting.
Yep temperature control is the secret to not wasting wood. When I'm down to minimum coals, I make a coal pile in the middle and open the side door and air. When there glowing, through on a few splits. Normally I can burn two side by side splits.
My kindling. S dry, 2 X framing scraps. Paper towel / toilet paper tubes.
I have probably close to 1/3 of a cord of kindling put up in bags (and a few barrels) I got from buying kiln dried wood. The wood is from branches and tops most of which is under 3" in size down to as little as 1/2". I do a lot of cold starts so I think it will be handy to heat the stove quick and for burning down coals. In addition on days I'm around I've heated all day on shoulder season type days with what usually ends up in the chipper or at the curb.
Reactions: CentralVAWoodHeat
We have lots of kindling in the yard & it keep the kids busy. As mentioned, good for the shoulder periods when you need a little heat or you want the chimney to warm up.. Likewise, when I need to burn down the charcoal chunks...I toss some kindling on top...works well.
Cedar pole pieces are the best being a lineman I have access to poles nonstop. The tops are dry and with no chemicals, they have been in the air for over fifty years. When we remove them for new poles the pieces that guys don't want I chainsaw into 16 to 18 inch pieces. It makes the best kindling or shoulder season wood to mix in with the maple and beech.
Reactions: zig
I bring in most of the branches from the trees I cut up and use the smaller stuff to chink in the cracks between splits.
I also use small stuff (1" or so) for cold starts- I lay down a bed of it and hit it with the propane torch to light it. (I tell my wife that this is because it's faster; the truth is that it's more fun.) =)
Getting all the branches processed takes more time than doing the "real" firewood, but it seems like a shame letting 'em go to waste... good BTUs in the little stuff too, if you have the time to mess with it.
Reactions: HisTreeNut
I wouldn't call it kindling, but I'm a big fan of 2-3" branch wood. Mixing w/ the large splits on reload gets the firebox hotter faster. I had no well-seasoned large splits my first year burning an EPA stove,so I scrounged and burned a lot of dead fallen branches and smaller standing-dead trees 1"-6" (and became a "branchburner").
I once posted how I had heated for an entire weekend on stuff that I collected off my lawn. Felt extra free somehow. Now I've got a bunch to play with. Should be dried by next season.
Reactions: edge-of-the-woods
Wood off the lawn/close to the house DOES feel "extra" free :)
Off-topic, but have you ever reviewed the Silky Katana Boy on this site? I just looked it up, b/c it sounds like something you made up, but the reviews I see on Amazon are incredible. Is this thing legit? They claim it "Can easily compete with a chainsaw".
I have it, I use it and it is very sharp. It is advertised as a tool for arborists, whether in tree or from the ground. Great for stuff too big for loppers and have used it on up to about 8" hardwood. Compete w/ a chainsaw is an over statement (it's human powered after all) but it can be quite quick under the right conditions. It is a pro quality tool with pretty good reach so it comes in handy especially for pruning and will get into places you can't get a bow saw or even a (conventional) chainsaw to. I have taken it on trail cleaning/creating jobs and it's mostly good for that too. I feel like it excels cutting stuff in the 3-6" range, especially when the cut is opening.
It has a narrow blade and kerf which I guess helps it to be quick but will bind easily if you're cutting on the wrong side of the bind. I have cut some wet pine that seemed to slow it down too when the wood sort of swells around the cut if you know what I mean or if the chips don't clear well. Meant to cut on the pull stroke so not real good as a one handed tool. Therefore if what your cutting needs to be held, its efficiency drops off.
I am a certified arborist even though I sold my business the spring of 2015 and don't practice arboriculture at the moment. I can say that All the Silky products are top quality, but they don't give them away. Compete with a chainsaw? Not even close.
I have probably close to 1/3 of a cord of kindling put up in bags.....
Where did you get the bags.. I've got a lot of kindling out back, and it is a real pain to bring it in once the ice and snow start to build up
When I am done with forest work for the day and need a 'cool down' and want to stretch out a bit, I split kindling.
I also occasionally purchase 2x4x8 untreated lumber and mix that in with my kindling. It is super cheap and kiln dried to well below 10% moisture. A couple times a year, I pull out the miter saw and buzz them down into 10 inch sections and then split them up.
Every year I learn something new....
How do you stretch your firewood supply and at the same time maintain a truly comfortable temperature?.....
I just cut more wood. It's essentially free minus the labor involved where I live. I am surrounded by ponderosa pine, juniper and pinion so I try to have more than I need and I am working on getting a year ahead, then two....that way I am always warm and don't have to skimp.
I got the bags a couple years ago when I ordered some kiln dried wood. They seem like the same material they make tarps out of but a little heavier and the weave is loose to allow air flow.
Not sure where to get them or what else they are used for. It seems like a good solution for storing and drying since there's no practical way to stack the stuff. Also good way to transport into the house and keep the mess down.
This is why you have kids...
I don't have any scars from splitting kindling but I have come close. I don't use much kindling during the regular burning season, but it is nice for cold starts.
My father gave me a Kindling Cracker for Christmas and it works pretty well. I would never have bought one for myself, but it is nice to have. It makes quick work of generating kindling and so far I don't have to do the work. Once the newness of it all wears off, the kids will let me try it out more. My biggest concern is that I will come home some day to discover all my nice splits have been converted into kindling.
I have so much kindling I'm thinking of just burning it in the stove as wood. I have three large plastic boxes of splitter scraps from this year which I baked in the sun and has been in the barn for months on the second floor so I'm sure it's dry as a bone.
In addition to that, I took down two ceilings which had 1 by 2 pine strapping, and rather than throw it out, cut it down to stove size. Some of the strapping might find the fire pit next year...
