There ya go jharkin, the next generation stove builder.jharkin said:To be honest I don't think its all that exciting. They just put a servo motor on the air control and hooked up a remote control to it. It would not be as elegant but I could build something like that with parts from an R/C hobby shop.
What would really be elegant is a system that uses inputs from a room thermostat and thermocouple temperature sensors on the stove. Have a simple logic controller that is programmed to fire the stove to the deisred room temps, with overrides if stove temperatures (stovetop, flue temp, catalyst temp if applicable) get to high. To make it really slick you could program some learning logic into it to anticipate hitting the thermostat set temp and start dialing down the air in advance.
Wow, first time I have seen this! Interesting.Huntindog1 said:http://www.inveninc.com/Images-Products/SmartStove-InformationSheet.pdf
What would really be elegant is a system that uses inputs from a room thermostat and thermocouple temperature sensors on the stove. Have a simple logic controller that is programmed to fire the stove to the desired room temps, with overrides if stove temperatures (stovetop, flue temp, catalyst temp if applicable) get to high. To make it really slick you could program some learning logic into it to anticipate hitting the thermostat set temp and start dialing down the air in advance.
