Trivia question
How thick does the layer of ash on your stove/furnace/boiler's heat exchanger need to be to reduce i
  • Total voters
    29
ScotL
376
Central Maine
I heard a statistic a little while ago but I don't know how accurate it is. If it is correct, it's something everyone would want to know. So I'll ask a trivia question and maybe those well versed in this kind of thing can enlighten us.
"How thick does the layer of ash on your stove/furnace/boiler's heat exchanger need to be to reduce it's efficiency by 50%?"
(Guess the poll question is too big to fit above, but this is the full question.)
gonna guess 1/8"
Seems about right.
Any amount of ash has to block thermal transfer.
Just my SWAG.
---Nailer---
I don't know, I can't see my stove's heat exchanger. There's a built in scraper that I pull in and out every couple of days.
Dave
I notice a difference after a week of burning, although I don't believe it's 50%.
I guessed 1/4" cause after 40 plus bags through mine and about 1/8" build up. Mine only dropped about 20ish %.
I'm guessing 1/4" also. I don't measure in weeks for cleaning anymore. I go in "months". Just did the Quad today. Not bad after almost 2 months. Still using Low, and still getting good temps..
1/8 inch. Sure screws up the ESP
The answer is: 1/8"
That's the number that I was told by 2 different people and both of them should know.
I've always heard that ash is an excellent insulator. Just goes to show how important it is to keep a stove clean.
Thanks for the info Scot, does not surprise me at all :cool:
I won't claim to be that smart as I had just gotten off the Goverments web site trying to check out how good aspen pellets were. Might try them as they are available for $200 a ton.
He says in a thread started by scotl......
Luckily you are not from the northeast. :-)
Luckily you are not from the northeast. :)
I try to keep my interest in this forum on a personal level. I have a PB105 at home and a Kedel at work and enjoy talking about all things pellet - no matter what brand. This is a great forum to both learn new information and to share what information you have (like the 1/8" thing in this thread). Don't worry about offending me in any way.
I knew you wouldn't take offense. I just had a chuckle in my head when I read his post. How do you like that kedel? They look pretty nice.
I didn't know that only 1/8" of ash caused that much efficiency loss.
It's a smaller capacity than my Harman but has a lot of features. But, that also means it takes more to get it setup correctly which it still isn't. It's supposed to have a compressed air pump, that didn't ship with it, which cleans out the burnpot. The fuel/oxygen ratio isn't adjusted correctly yet either. And I don't think they installed the correct exhaust ductwork on it. They put on something you'd see on an oil furnace - with a draft damper.
Eventually I think it will be a really nice unit.
