Hi,
I have a Napoleon epi3 installed in an exterior chimney, non insulated 6” flue, with roxul as a top plate (stuffed in between flue and brick). I wish it heated my family room better, with house heat set to 68 I can’t really get my 300sf family room above 72 or so. Of course the family room is open to other rooms so heat is escaping.
Have a few thoughts and would appreciate feedback;
- While roxul is good stuff, by not haven’t a sheet metal plate am I losing much heat up the chimney? Seems like the roxul is doing a good job of preventing any draft.
- The fan isn’t the strongest, you can’t feel a breeze until your hand is about one foot in front. Always thought it was a little weak, but maybe thay’re not supposed to be too strong. I’ve played around with adding a small fan blowing across the front.
- Once I get things going I add a couple medium size logs every hour or so. While flames do “lick” the top tubes maybe I’m not filling it up enough. I’d say the firebox is maybe half full. Since the firebox isn’t too deep it’s hard to stack longer wood without a lot of them not being east west and therefore not always stacked the best.
- After an hour or so I start closing the air intake lever so the fire isn’t going too strong.
- Wood; seasoned well, at least a year. Use poplar to get things going, then locust if I want something that will burn longer (my locust wood weighs about 2x as much as the poplar).
- Thinking I was losing heat through the sides and back of the chimney brick, I thought about lining the chimney walls with roxul around the insert. Napoleon didn't like that idea so I didn't.
- Do most people do as I do with adding a couple logs at a time or is it better to load it up more? Maybe this is the simple reason why I’m not getting enough heat.
Thanks!
Thanks!
