Trying to get more wood heat on a budget have fireplace heatilator
afptl
135
Northern KY
Newbie here, looking for some suggestions. We are trying to get a wood stove or insert in our fireplace. Our fireplace is actually a heatilator unit, but just doesn't heat enough to waste the wood on it. I measured up into the damper, and it is about 6 inches wide.
My hubby and I went "stove shopping." WOW were the new ones pricey! Can't do a new one, hubby's business is just down too much for that kinda cash. Trying to find a decent used unit. Our goals are: something that will generate heat when the power is out, a flat top to cook on when the power is out, and if possible a way to occasionally view the fire. (screen?)
Our home is a well insulated ranch modular home on a full basement. We have a Crosswinds Wood and Coal furnace in the basement for when it's really cold, but it's too much when you need a little heat. It's either no heat or windows open and 76 degrees on the main living floor. We could use a stove on the main living floor so we could just have a little heat when you need some heat but not the overkill that the Crosswinds does. I think the Crosswinds is too big for our home.
One of my questions is: is it really necessary to reline the fireplace chimney? it is 20 years old, not been abused and is the clay tile stuff. The reline is making the whole idea SO EXPENSIVE. What about just shoving an insert into the hole and letting it draw up? Any ideas to make this happen? thanks for any help and God Bless! Ann from KY
First of all, welcome to the site. I also have a ranch, no basement, just a crawl space and my backup heat is all electric (ouch...). I actually just wrote this is a post like 2 days ago:
My recommendation would be to start searching craigslist daily when you wake up, at lunch, and after dinner in search of a new stove. Give it a few weeks and you’ll find someone who upgraded to propane or natural gas that is just looking to get rid of a nice insert for cheap. (I did the same thing for my splitter). They go really fast, so make a schedule of searching regularly. It is going to be hard for you to find an insert that also has a full cooking surface. Someone else can probably help you with that, my Regency only has a small ledge on the top.
You really should buy the liner, mine was like $500 total. When I bought mine, I bought the thickest flexible liner I could find and the insulation to help with the draft.
I bought my Regency insert for $300 and the liner for $500. Full installation was only like $600 after I bought the additional parts and sold the old stove to someone looking for a small one for their workshop.
With the people on here, you can do anything stove/flue/installation/burning/firewood/seasoning related. Really a great site.
  • [Hearth.com] Trying to get more wood heat on a budget have fireplace heatilator
I actually just put my insert on Craig's List. I'm looking to upgrade before the tax rebate runs out. I wish I could help you out but thousands of miles separate us. Keep an eye on Craig's List. You'll find something good and reasonable. In the mean time research liners. They are highly recommended around here. I have one and I get great draft and fantastic heat out of my small unit. Good luck!
What's a realistic budget Ann? This is a lousy time of year to look for a bargain, but in another 30-45 days, prices will come down. Are you eligible to receive a tax credit? If yes, you might consider an Englander 13NC if it will fit your fireplace. At 30% off with the credit, it is better priced than many used stoves. Add a liner if you and hubby can DIY and it should be under $1800 minus 30% or $1260 or less. If that works (measure up first) then order very soon.
http://www.overstockstoves.com/50tnc13i--epa-certified-noncatalytic-wood-stove--1550131500.html
