Turbulenz Ash Vac
Looks just like the power smith ash vacation. Probably same manufacturer. Go for it.
I'd go for it. My ash vac is the loudest POS on the planet but forget the brand. It was also a little more money than 60 bucks.
Just for my education only: How and for what do you guys use these vacs? A wood stove, or something else? I've never had the urge to do anything but use a straight blade shovel into a metal bucket (a wood stove). But maybe that's old school. What advantage do the special vacs have? Thanks.
I mostly use mine at the end of the season when doing a good cleaning of the stove -- above the baffle, in the firebox, etc. . . . always several days after I have had my last fire.
In the past I also used it to clean up around the hearth . . . but mostly these days I use a small whisk broom.
Reactions: DUMF
never owned one, but when i had a wood stove in the house i would of loved to had one for sweeping up fly ash around the stove. they are designed so that is you get a hot ember it wont catch on fire.
I use an indirect ashvac. That is, it does not have it's own motor you push your regular vacuum cleaner hose into it. It does have its own filter.
I only use it for small amounts that cannot be picked up with a shovel and I use it when I sweep the chimney. (see similar in link below):
(broken link removed to http://www.ebay.co.uk/itm/Ash-Can-with-Hepa-Filter-for-Vacuum-Cleaner-18L-/202025485348)
No they will still catch fire. The filters are very flammable.
It is just a rebadged Powersmith. I have two of them. The filters are made of fiberglass. But they ain't the most powerful suction around. I don't know what they are using that 10 amps for and I have no desire to suck hot embers into them to test flammability.
Reactions: seaninnj
I own one purchased at job lot as well. It’s a 40 gallon. It works great! Only problem is finding filters. I just found a 12” filter on eBay for 20.00. The secondary filter fell apart before first season was over. But the motor sucks real well. Anyone have suggestions on filters?
I bought an ' Ash Vacuum K-601 a few years ago. I've only used it a few times, not for ashes, just general clean-up. When it runs, there is an electric burning smell and the top of the vac gets very warm. The air coming out of the ports, whether the hose is used to vacuum or blow out gets very warm. Is that normal for the model?
