Ugly leaner finally got prettier. New Pics
skyline
Burning Hunk
191
Oregon
I have had this ugly dead maple right along side the driveway that blew over only to be held up by a big fir. I have been afraid it might fall sometime when we least expected. I figured if I cut it off the stump it would just slip towards the tree that was holding it up, and then I could drag it from the butt back keeping well out of the way. So that was the plan!
The cut worked out, it slipped off the stump. But when I dragged it back the top broke off and instead of crashing to the ground, it landed and stayed balanced on a 3 inch branch 60' up. Now I have a true "widow maker".
I'd know what to do if I had an extra stick of dynamite but am open to suggestions. Let me know what you think.
  • Ugly leaner finally got prettier. New Pics
Wow, that's crazy. Maybe shoot the 3" branch with a shotgun?
Reactions: smokinj
Jay Browning from "Axe men" would drop a nearby tree onto it and take it down that way. Other than that I have nothing for you. There looks like a lot of brush around. Be safe.
Wait for mother nature or get a man lift and go up and cut it.
Reactions: smokinj
You could drop the tree that has the widowmaker in it. Or pray for a really windy night real soon! Either way, if that thing is right next to your driveway, it is an accident waiting to happen.......
Reactions: smokinj
Tie it off as high as you can, to only fall in one direction while cutting down the one its leaning on. Then cut the one its leaning on and escape in the direction opposite the direction its tied. This could be your last tree. If your not confident of your abilities, hire a professional company, it could be the best $5-700 you ever spent for a tree service.
Deer rifle on that 3" branch.
Man it is almost creepy how much moss you guys on the west coast have!:)
Gary
Ha, that is the dry country moss. Out on the coast it's a whole nuther story
. Ugly leaner finally got prettier. New Pics Ugly leaner finally got prettier. New Pics
Reactions: ScotO
If there is danger of the remaining branch hitting someone on the ground (unaware of the danger) I'd hire a bucket truck. Otherwise, I'd flag the area under it with caution tape and wait for Mother Nature to fix it.
why cant you just yank her the rest of the way down? stump in the way? put a snatch block out there and pull from that. just a suggestion.
cass
Reactions: smokinj
Do you have any hunters in your area? A climbing stick or a climbing tree stand can work wonders with this sort of thing.
Reactions: ScotO
A good sized backhoe could lift/yank the bottom out in the desired direction. Probably the same cost as a pro arbor though but the hoe could clear some of that brush.
Reactions: smokinj
Thanks for all the ideas. Based on some of the responses, I'm not sure it's clear that the 20' top is resting on a branch 40'+ up from the base of the maple it's resting in. Here is another picture before I yanked the bottom out. You can see how the top fell about a foot before landing on the branch just below the break. I'm not really interested in climbing the maple with that much top directly overhead and I don't like the idea of cutting underneath it, besides it's my neighbors tree. The lift would probably be the easiest as any hoe I have access to wouldn't be big enough. I'm thinking if I can get a line up there, I should be able to pull it over.
Was gone all day today, but we had some decent winds and it still didn't come down.
Yeah, I'd either shoot it out or see if i could get a guy with a bucket truck to do it for a few $$. Maybe you can find someone who would do it for $cheap$ on their way to the real job that day. I have a scary left over from our October storm that I have to do something with sometime soon.
Thats a mess........If I could use a line an tractor/winch I am out of there.
20 feet of chain tied to it and my truck has always worked for me in the past.
Reactions: smokinj
Something like this has worked for me..
Cut a wide notch about 1/2 way thru the trunk as far up as you can comfortably do..
Make a cut from the underside of the log up towards the bottom of the V nothch. DO NOT CUT ALL THE WAY THRU.
At some point this hinge you've made will start to 'fold' and the top off the leaner will move downwards the length of the short piece possibly freeing the top.
This can be repeated depending on the angle of the leaner.
This hasn't killed me yet.
Free advice is worth every penny.
My woods are so thick this happens quite often to me. I wrap a chain around the tree (down low) and chain a comealong to another tree(high as possible) and start pulling. I have done what gerry100 does, it probably isn't very safe.:(
Reactions: smokinj
As I read it, the trunk was successfully dropped, but the top remains hung, well above an easy, safe reach for attaching rope, cable, chain, ...
Call a tree service or an arborists that does rope climbing up in the trees. They have what they call throw bags that they use to get there ropes into the trees. The small line that they use to throw the bags has a breaking strength around 1000 pounds. Most experienced guys could easy throw to that height and use the line to pull it down. It would probably be a 10 minute job.
Cable on butt, pull out with tractor. What am I missin'??
The OP, but you're in good company. Guess I wasn't clear.
Flamestead, thanks for understanding the problem. I didn't have any trouble cutting the leaner off the stump and pulling it away. And I did use a block chained up in another tree for some extra lift. My OP was pointing out that the top didn't come down but broke off and was balancing on a 3" branch.
I have a throw bag for that purpose but for limbs this high they have crossbows or sling shots for launching lines, neither of which I have, but I came up with a decent work around. I have plenty of tennis balls around the house for the dog. Drilled one through and tied my throw rope to it. Tested it out and made it over the branch on my 2nd try. Unfortunately, the ball alone wasn't heavy enough to pull the line down so I had pull it back and stuff the ball with some nuts(buckshot would have worked better) and try it again. It didn't hit quite as well with the nuts inside and I only had a 2' window to hit it through. I stopped counting after 10 tries. Luckily, the tennis ball kept the string from getting caught up in all the brush when winding it in and it only took a minute for each attempt. The top and branch angle pinched the line once I got it over so I had to use the truck to transition from throw rope to pull webbing and again to my haywire. The throw rope would have broken long before this branch. With both ends of the haywire attached to my truck tie downs, I was able to pull until the branch broke and the top fell out. It ended up being just over 35'. The only casualty was the strings broke on an old tennis racquet.
It worked so well I left the ball on my throw rope as I can hit it twice as high as I throw the weight and with better accuracy.
My solution.
Throw rope finally over.
Got the webbing around.
Transition to haywire
On the way down!
The offending branch and solution.
The butt log and all 3 parts of the top.
  • DSC_8914.pdf
