Actually this thing was burning hotter than ever...on just the #1 setting it was 96 in stove room with 10 deg outside.
I just finished paying 150 to a shop to clean it ...and extra 100 bucks for a new exhaust motor and 25 to install it...I am gonna try to fix the bend on the ash bin AND call the parts place for a price on a new ash bin..if they can find one.That burning soot is probably creosote built up burning off created by the poor burn before the airflow fix. I would be very inclined to inspect the venting before burning further. You may find the black nightmare in there. If the stove was given a good hot run it may have just burned most of it off but if your concerned give it a check anyway. Won't hurt to clean the rest of the stove before running again with a repaired ash pan.
The creosote was not cleaned out originally or caused by the leaky ash pan. Sounds like the latter.Just want to make sure your stove is safe and sound. Venting fires are very not cool.
As soon as I figure out how I will post a video of the latest firing up of my stove...set on 3 (Harman P38)Look forward to hearing how you make out!
You will see some smoke during startup. Duno,That flame looks pretty good to me.
::edit :: we're you seeing smoke while taking the video?
actually at the 6 min mark you will see what looks like flames but its not its smoke i noticed that the seal i was using to try to seal the burn plot cover is not holding I have a broken thumb screw and cant get it out to replaceYou will see some smoke during startup. Duno,That flame looks pretty good to me.
yes we have tried 3 different brands of pelletsOh ok I saw it that time. I need to review the thread and refresh my mem on what's been done. There still appears to be an airflow issue. Have you tried another brand of pellets?
Your talking about the igniter access cover. That will need to be fixed. It may be possible to drill the center out of the broken stud and remove with an easy out. If it's too cramped you may need to remove the burn pot to fix.
That access panel could be the last piece of the puzzle! If it's coming loose and not sealed properly that would affect air flow for sure. You might get luckily and just trying to drill it might turn it through. You'll fix her up. Good luck and let us know how you make out!
