UPDATE....Harman PP38 Box fire update
Center punch the old screw and find a cobalt bit to drill it out. You only get one shot at drilling it out. If you don't get the screw out you may use a self tapping screw to get through the season. Then have to consider removal of pot. Good luck
considering the drilling out of the screw..might be the best way...
the way the screw snapped off isnt flat...its more of a twist off..so I have to use a metal file to file it down some...will purchase a toool to remove screw tomorrow.. Thanks
Good luck either way. I've never had much luck with so called easy outs. Still need to drill. I have been removing old broken bolts and screws for along time. Portable welder makes the job easier as I could have welded on a nut and the heat would have probably broken the grip.
Thankyou for the help!! joe t
OkNow I am beyond lost...fixed the broken screw on the plate below burn pot...started it up and after 6 minutes of burning the flames begin again in the ash bin..spoke to a stove tech and he thinks the exhaust motor is sucking flames down from the pot..
the flame in the pot is full..stretches up to the heat transfers....still getting some soot also..
I am completely lost..
Circuit board issue/voltage?
Ok. Just to verify ...the igniter cover plate is now held on tight with two screws and sealing properly? Should be flush against the burn pot with no visible gaps.
I an still inclined to think that there is an airflow (leak) issue. If the combustion motor was sucking flames down (too much air flow) I would expect that ash and possibly burning pellets would be expelled from the burn pot. Maybe you are seeing this? The video you posted seemed to indicate a decently active flame. In your observation what is causing the flames in the ash bin? Have you checked that the door and pellet bin seals are good? Is the fines cover seal in good condition? Seated properly and on tight?
I chcked the fines cover...I was able to turn the thumb screw 2 turns...I thought they would have done that when cleaning it..
2nd..I inspected the circuit board..I noticed that the black wire that runs from the blower to the board was not connected properly..I pushed it back onto where it goes...is this a possible problem??
did the paper test on the ash bin.....the paper slid out of the top edge curling the paper...the bottom edge (front) either I cant get the paper in correctly or its so loose that the gasket isnt touching cause the paper slid right out....
I did my best to straighten the bow in the ash bin ( unable to find a replacement at parts store)...
You can try a lighter it will get sucked in if there is a leak. I find that a bit more definitive then a paper test, but if the paper is pulling out easy you most likely have a leak.
You might try a thicker gasket rather then trying to bend, problem with bending is it bows out somewhere else maybe introducing a new leak.
was gonna use a 3/8" gasket...cant find 1/2"...I do have some 5/8" but that might be too much.
Thanks for the advice...I was able to follow your directions...but I had to re tap the hole for the replacement screw...plate fits flush now.
Well sounds like you got it repaired properly and won't have that problem. Did you apply a antiseize compound to the screws so they will not be a problem when servicing in the future? I use the stuff on anything that may stick or want to remain movable. Door hinge pins are a good one.
Well ofcourse(just messing) not..I totally forgot that one..was so excited to get another step completed I dodnt think that far ahead...well atleast next time I have the tools needed to make the repair..
Thanks for the advice..helping a ton.
Tested with the 5/8" gasket...its gonna be too thick....I still have a replacement 3/8" but if there is a small bend then then it wont work...Will take a ride in morning and try to find 1/2" gasket.
replaced ash bin gasket with a 1/2" gasket..will see if it works!!
OK..I think I finally have this thing fixed...last item to fix was a new gasket on the ash bin..It calls for a 3/8" on the old p38 but 1/2" on the newer models..I replaced with a 1/2" and although it was very tight to close the hinges...it seems to have done the trick..burning good and no more flames being sucked into the ash bin...
Will post picture and video if possible.
Thanks for all the help.
joe t
joe t
And ofcourse that damn flame in the box comes back!!!
The phantom flame is back in the ash bin
Seems as if the feed may be to much? Are Burning pellets dropping over the edge?
To many pellets will result in Smoke and High temps. The smoke and high temps will allow secondary combustion to occur. This is happening when the Hot gas/smoke comes near the glass' air wash.
That's my "Guess". What settings are you running on? Is that pretty close to Full Bore? Have you tried backing.it off? Setting the burn rate for the 1" ash lip from the end of the pot? (Burning pellets shouldn't drop over the edge).
The above video is with the stove running on 3 (feed knob)
Even with the feed running on 1,2 3,4, 5 or even on turbo...I shouldnt get any of what I am seeing...
I am taking it to the Harman repair service at the local Harman stove dealer tomorrow...I explain it to them and they are also stumped...if no air leaks then maybe a voltage issue on the circuit board.
Its acting as you have to much fuel and not enough air. Exaust fan not up to snuff? Did you check with magnahelic to see if you have enough draw?
I dont have one of those...I am probably taking it to a repair (harman dealer)..the tech thinks it may be a circuit board issue restricting power to the exhaust fan....Ibought the exhaust fan new from the harman dealer and had it put on......leaning towards that being the problem...if so its gonna cost..will need an upgrade to a new board..almost 300 more bucks..
