Back before the season started I posted a thread about an experiment I did with my old insert out in the East 40. In a nutshell I burned the dickens out of it with continuous loading of dry cardboard. In the first place to dispose of a huge bunch of cardboard I needed to get rid of without filling up the landfill and secondly to determine if people that measure their insert stove temps with thermometers over the door were getting accurate information.
The results of the outdoor test were that the front of the stove body consistently was 100 degrees less than the temperature of the top plate of the stove measured centered halfway between the flue collar and the front lip of the top plate. Since the insert being used was a pre-EPA beast a legitimate question was raised whether this result would be consistent with the same test done with an EPA re-burn insert since the hot flue gases of the EPA unit are blown toward the front of the stove and they smack into the front of the stove prior to exiting over the front of the baffle. Well the results are in.
For the last three nights I have made the same observations using my Englander 30. The same construction as a standard tube type reburn EPA insert. And at every stage of the burn from 300 degrees stove top temp on up the temperature measurements on the front of the stove above the door was almost exactly 100 degrees less than the temperature of the top plate measured centered on the lower step of the top.
This is just for information purposes and because I like to play with wood stoves. Others are encouraged to verify the results as true on other stoves or as the biggest crock of it since Bub suggested burning green wood.
