upflush toilet in basement bathroom
rkofler
Burning Hunk
Nov 15, 2011
156
Long Island
I'm looking to finish my basement, and the wife wants a bathroom. Unfortunately the only waste line in the bathroom is from the kitchen and runs along the top of the basement wall. The bathrooms are in another part of the house that is on slab.
So I'm thinking my best option would be an upflush toilet that pumps into the kitchen waste line.
http://www.upflushtoilet.com/
Anyone have any experience with these? Pros/Cons?
My biggest question is in regards to venting. Would be real tough to run pvc from basement through roof. Are there any other options? Heard about something called a studor vent, not sure if I could use.
Thanks for any feedback in advance.
Ron
Does she want a full bath or 1/2 bath?
How's your water table?
I went with a saniflo unit after advice from my plumber in law that it was a bad idea to cut into my slab. I live in a swamp and the water is about 2' below my slab when the river is running through the yard. 4 years no issues.
Just going to do half bath. No issue with water table. Seem to be reading good things about the upflush, my concern is the venting. Will probably have to ask a local plumber.
Thanks, Dune. I did read through that post. I'm not looking to break up basement floor though. Is why I'm looking at the upflush.
I think Saniflo would be a great deal/ $1000 and it's done. Personally I have one of these under my slab: (broken link removed)
I have not had any issues at all. Love the pump.
I have installed many Saniflo units. The toilet has a 4" outlet out of the back like a commercial wall hung. The ejector pump exits at 3/4 or 1 inch. Very easy to install! I have the gray water from a shower and a vanity draining into the same ejector pump.
Reactions: Swedishchef
Thanks for the feedback! I am also looking to drain a sink into it. Also thinking about draining a dehumidifier or air conditioner into it. Can't imagine that being a problem...
My biggest question is the venting. Can you explain how you typically vent this system?
Good option, before these all in ones we would use regular toilet and separate macerator pump...
If the vent stack is near you can tie in there or run a new one.
There is no vent stack at all in the basement. Running a new one would be tough. Any other options?
As Retired Guy stated.You can do what he suggested. If you have first floor bathroom. And can see the drain line from basement and can find the where the vent in the wall is. Then come up from the floor and cut and tie in. If acceptable by your local plumbing code.
