I'd like to consider adding a UPS to manage the load when we drop utility power before the whole house generator kicks on. I'm very familiar (and have spares of) UPS for computer equipment which don't tend to like having motors driven off of them. Has anyone done this and can comment on any gotchas and if it worked ok?
Our windhager pellet boiler runs from a dedicated 20A 120V circuit and, if I'm reading the specs properly, should draw much more than 1kW during startup but I'm less clear on the draw from the vacuum to refill the hopper or the motor that scrapes the ashes into the bin. Either way a 2200VA UPS should be big enough - I hope a 1500VA would do the job but that's undersized if a 20A circuit is really needed. Since most smaller UPS can't take a hard-wired connection, I would imagine taking the feed for the boiler's dedicated circuit, adding a plug to connect it to the UPS. I suspect that is not code compliant. Perhaps a small automatic transfer switch on the boiler feed?
The reason for all of this is that our boiler does not seem to like losing power. The control panel doesn't always come back until a couple of reboots. In addition, we have had some unburned particulates blasted out of the boiler enough to set off the smoke detectors the next time the boiler fires after a power outage.
Has anyone done this and can provide some feedback and lessons learned?
Thanks
Thanks
![[Hearth.com] UPS on pellet boiler? [Hearth.com] UPS on pellet boiler?](https://www.hearth.com/talk/data/attachments/307/307926-db2cc9bb998eee4ea0d4684c458b342b.jpg?hash=A1snyTKE7O)
