Hello. I have a vermont casting encore with a cat. I have used wood stoves for cooking and heating for over 10 year in previous homes). It has been installed in my new (well very old victorian) house for 14 months. It sits in the LR and goes into the ceiling with one elbow join (I wanted to use the hole from the previous stove that was there). It then goes up through an upstairs bedroom straight, up into the attic (which is like a full third story) and then has one more elbow join to get it out of the roof. It was professionally installed. My wood was delivered last year from a reputable source. All hardwood. The stove functioned perfectly all winter last year. I had enough wood left over for this year so I stacked it on pallets correctly and it has had another year to season even more.
I clean the stove once a week including the cat (v. gently) according to my manual.
This fall when I started using the stove again everything worked perfectly. By working perfectly I mean that I get a fire started with kindling. Add some small logs. Add medium logs and wait a few hours for a coal bed. Then load in a couple of big logs through the top and engage the cat/ damper. Before I go to bed I un-engage the cat, add more wood to the coal bed, reengage it and sometimes turn the air down. In the morning I un-egange the cat, add small logs wait about an hour then load it up and engage the cat and leave for work. Using it this way means I don't ever have to kindle a fire in the morning or evening because of the coal bed. I only kindle a fire when I let it go out deliberately to clean it. So to me this is wonderful and I thought I was using the stove correctly.
On saturday we had temps of -20 degrees in the morning. When I woke it followed my normal procedure. Suddenly the stove started "burping" smoke through the top loading door, the front doors and all the chimney joins in the LR including where it enters the ceiling. I called the installer. They said to shut the stove down. I carried the smoldering wood outside and it took a long time to clear the house of smoke. On Tuesday they were able to send someone out. They felt the chimney pipe was obscured. He cleaned it from the bottom up (so not from the roof). he said there was barely any creosote build up at all. he couldn't get a fire to draw (using cardboard and small kindling). the smoke just pours out of the doors and the joins.
Then they said the back drafting and poor draw was likely a very cold chimney. The temp here now is 30 degrees. So 50 degrees warmer. I was told to start a very very hot fire and warm the chimney. Last night I did that. Smoke billowed from the doors and the joins. Closing the doors put the fire out. I kept the doors open and while it took an hour finally I could feel that the chimney was warm in the upstairs bedroom. The chimney pipe in the living room was almost too hot to touch.
But still with that hot hot fire, adding anything larger than two inches would give me smoke again. Engaging the cat - smoke. I was finally able to close the doors and not have smoke but I can't add any new wood that's not tiny tiny without getting smoke.
What is so odd to me is that the firebox clearly fills with smoke when I add wood. I can see it through the glass doors. Then it starts to leak out of the chimney joins. So this morning I checked that the damper and air flow system inside the stove was not blocking anything and I can put my hand up and into the chimney pipe. It's hard but my hand is small. So the opening from the firebox to the chimney is there. The smoke just won't go up the chimney. The installer has no good ideas for me yet.
I'm trying to attach pics. One from the initial installation. Then one of the spot where most of the smoke is coming out where it goes through the first story ceiling/ floor into bedroom. One of the stack. You can see the smoke damage on the joins that wasn't there on Friday night. There is no smoke leakage in the upper bedroom or attic. Those pipes are double walled I think is the term.
Any ideas or help would be appreciated. It is my primary source of heat and the house is in the 40's.
