My "Split Air" heat/AC unit wasn't cutting it when the temperatures dropped outside. When it was 20 degrees outside, my split air barely got us to 60 degrees inside. I picked up a little wood stove (US1269E) at Tractor Supply and installed it (single wall pipe 6' to an elbow, then 4 feet out the wall to a T, with 6' of pipe up to the raincap). Since firing it up, we've been toasty warm on cold nights. The problem is that I can't seem to get the temperature of this stove above 300 degrees (according to my Imperial stove pipe thermometer). It's heating about 1,000 square feet and it gets mighty hot in here when it's going... I usually leave the windows open to regulate the heat. I know I need to get the temperature up to around 400 to burn cleaner and avoid too much creosote, but this stove just doesn't seem to burn hot enough. There are no controls to allow more/less airflow. I got frustrated and added a damper, which doesn't increase airflow. Cracking the door open a bit really gets the temps up, but also fills the cabin with smoke, so that option is out. I checked the goofy air intake below the stove and made sure the internal ducts weren't plugged. All looked ok. It's just a crappy design. Worried about creosote buildup at these low temps, so thought I'd clean the pipe... but can't access the pipe from inside the stove due to the goofy 2nd air chamber. This stove has been more frustrating than anything. I should have found a rusty old antique one at a local farm sale... but if you heat fast, you get what's available.
- can't control air intake: anybody got solutions to increase air intake?
- can't clean the pipe with the secondary burn chamber between me and the pipe: how do you do that? Disassemble the chimney pipe?
- can't seem to get the stove pipe temps up to 400: am I the only one having such a problem with this particular stove?
- anybody got tips or hints on using this model stove effectively?
(If only I could get my hands on the old antique stove from Grampa's hunting camp... that was a neat little pot bellied stove that was a snap to operate!)
Thanks,
- Bax
Thanks,
- Bax
![[Hearth.com] US Stove (US1269E) - any tips? [Hearth.com] US Stove (US1269E) - any tips?](https://www.hearth.com/talk/data/attachments/334/334361-aae359fa9710f7c1c76632faec9cff00.jpg?hash=E2B_cvGAcP)
