Vacuum error in USSc model #5660
EMF
1
Vermont
I have tried to follow the manual to fix this, but it didn't work. I replace the gasket around the glass and it still doesn't work, keeps flashing #1&2 for a vacuum error. What else can I do?
Have checked the door gaskets and ashpan gasket with a dollar bill?
If they pass than check the tube going to the vacuum switch is not clogged or cracked.
If tube is good, put a TEST jumper between the two wires connected to the vacuum switch and see if the stove will start and run. DO NOT LEAVE THE JUMPER IN PLACE BEYOND THE TEST RUN!! The vacuum switch is a very important safety feature.
