In the last couple of seasons I've had soo many shut downs due to accumulated sawdust in the bottom of the hopper that I even considered replacing my Quest Plus with a wood stove. It's a bit depressing to come home to an icecold house time after time... and the sight I saw EVERY time I had shoveled all the pellets out of the hopper, was that of the picture below.
Then I remembered a tip I got from an experienced pellet burner: Try to pour a little vegetable oil over the pellets when the hopper is nearly empty. This way the sawdust will cake up and be made transportable for the auger screw.
A month ago I started my experiments. Result: A tremendous success!! No more shoveling pellets and vacuuming off the hopper.
Note: Only a very small amount of oil is necessary ( one to two tablespoons ) and it must be used preventive in this way: When the hopper is nearly empty, I sweep the remaining pellets and the sawdust in a small pile towards the intake and pour the oil over it. Hmm, a brush soaked in oil may be even better to ensure a limited dose. That will be my next experiment.
Caution: Too much oil should be avoided. The rubber gasket on the end plate and the auger bushing on my stove are not 100% tight, and one time, when having added too much oil, I noticed that the oil would leak out under the auger inside the stove. Also, I could imagine that it may be a fire hazard if the drop chute is all wet of oil... the fire might spread to the hopper in the worst case!!
The oil I use is rapeseed oil/canola oil and it costs the same as diesel oil around here: About $2 for one litre.
BTW, some years ago Shell sold some Super Premium pellets here in Denmark that had been impregnated with rapeseed oil during the pressing at the mill, I tell you, these pellets are the most energy intensive pellets I have EVER burnt!! They don't make them anymore. They were expensive and perhaps they were too good?
But hey, maybe bad pellets could be turned into premium pellets be brushing/spraying them with some rapeseed oil? Hmm, that will be my next experiment. I'll let you know how it turns out
Important discovery: Vegetable oil does NOT disintegrate/destroy the pellets turning them into sawdust like water does in a couple of minutes.
This phenomena is puzzling me, and I think the explanation has to do with the nanostructure of woodfibre: It was created/made to enable the living tree to transport water and minerals from the root to the branches, leaves and fruits.
![[Hearth.com] Vegetable oil instead of sifting... it really works!! [Hearth.com] Vegetable oil instead of sifting... it really works!!](https://www.hearth.com/talk/data/attachments/85/85320-1aa5e9445fdb018cc1f7d4921e407d86.jpg?hash=NPQ_yOcPTz)
....but good info nonetheless
![[Hearth.com] Vegetable oil instead of sifting... it really works!! [Hearth.com] Vegetable oil instead of sifting... it really works!!](https://www.hearth.com/talk/data/attachments/85/85327-ed0fa08c87629e7c014aa473c4fa0fd3.jpg?hash=s1BN_qXvbe)
![[Hearth.com] Vegetable oil instead of sifting... it really works!! [Hearth.com] Vegetable oil instead of sifting... it really works!!](https://www.hearth.com/talk/data/attachments/85/85329-fd6e3df9cb2b131cba6cef88d32103f1.jpg?hash=1z4MsmlWba)
![[Hearth.com] Vegetable oil instead of sifting... it really works!! [Hearth.com] Vegetable oil instead of sifting... it really works!!](https://www.hearth.com/talk/data/attachments/85/85333-65e6f67f83e4e9ef5ff63ba83b46eec1.jpg?hash=Mj9Jprn5xi)
at night!! What do you do in a desperate situation?
