Hello Everyone,
I have a question I've been pondering. A little background. Remodeled my house and tore out the old wood burning fireplace and chimney and installed a new wood stove (more of an insert actually). The chimney is all new, constructed of metal studs, high temp insulation between double hardboard walls. Everything within a foot of it is fire resistant. One side of the chimney faces the exterior for entire 15' run up. Inside the chimney is a stainless liner connected to the stove and cap on top of chimney. Inside dimensions of chimney are 9x10 and the liner is 6" round.
Now to the question. When burning the stove I notice that the chimney gets quite a bit warm from the outside, especially towards the top, from the stainless liner which is not insulated. Is there a need to release all that hot air via some sort of vent that can be opened only when burning? Or the temperatures inside the chimney "dead space" (between block off on top of stove and chimney cap) don't reach high enough for me to worry about this? I was thinking of pouring insulation mix down the chimney but there seems to be an argument on this subject.
